Before every great day on the water comes a little care and maintenance, and your boat's upholstery deserves special attention. Chaparral’s Envision Performance Marine Upholstery™ is engineered with 100% SiO™ Silicone technology, providing exceptional durability, comfort, and resistance to UV rays, mildew, moisture, pink staining, and sunscreen. While this advanced material is built to withstand harsh marine conditions, regular cleaning helps preserve its premium appearance for years to come. Fortunately, maintaining silicone seating is simple and requires only a few basic supplies. With the right approach, you can keep your upholstery looking showroom-ready season after season.
How to Clean Your Boat Upholstery in 3 Simple Steps
What You'll Need
Step 1: Remove Everyday Dirt and Debris
Mix mild soap with warm water and use a soft cloth to gently wipe down the upholstery. Focus on areas where dirt, sunscreen, food, or beverages may have accumulated. Avoid aggressive scrubbing, as silicone upholstery cleans easily with light pressure.
Step 2: Treat Stains Quickly
For tougher stains or dye transfer from dark clothing, swimsuits, or beach towels, apply a diluted 50/50 solution of 70% isopropyl alcohol and water. Gently clean the affected area and allow the solution to lift the stain. The sooner stains are treated, the easier they are to remove.
Step 3: Rinse and Dry
After cleaning, thoroughly rinse the seating surface with fresh water to remove any remaining soap or cleaning solution. Wipe the upholstery dry with a clean, soft cloth. Drying the seats helps maintain their appearance and prevents water spots.
Just as important as knowing what to use is understanding what to avoid. Traditional vinyl cleaners, protectants, wax-based products, power washers, stiff brushes, abrasive scrubbing methods, and harsh chemicals can damage silicone upholstery or leave unwanted buildup. Instead, use soft cloths, rinse surfaces after cleaning, dry seats thoroughly, and store your boat clean and dry whenever possible. These simple best practices help protect the material's color retention, comfort, and long-term durability. By following the manufacturer's recommended care guidelines, your Chaparral seating will continue looking and performing its best for many adventures ahead. For more information regarding your upholstery check out Nassimi’s information center for more in depth cleaning tips. Information Center - Nassimi Textiles
